查看: 2367|回复: 0
【USB Flash】AU6986 D53-GHL-GR A639883 [复制链接]
发表于 2011-11-9 07:55:27 |只看该作者 |倒序浏览
Controller marking :  AU6986 D53-GHL-GR A639883
Number of parts :  4
Memory chip ID :  0xECD755B6
Capacity(Mb) :  32768
Variant 1 Author: anaktisis [1]
Parts of memory chips (8)
13570246
Change order (New order 1,3,5,7,0,2,4,6)
Translator Type 13 [AU6983,AU6986]
Bank Size1024
Block Size8192
Add-Ins Size64
Add-Ins Offset12
GMT+8, 2026-7-12 23:01 , Processed in 0.101932 second(s), 13 queries .
