查看: 2562|回复: 0
【USB Flash】AU6983 ????? ??? [复制链接]
发表于 2011-11-9 07:16:21 |只看该作者 |倒序浏览
Controller marking :  AU6983 ????? ???
Number of memory chips :  4
Memory chip marking :  HY27UA08T2MTR
Memory chip ID :  0xADD514B6
Variant 1 Author: dataworks [2]
Initial memory chips (4)
Change order (New order 2,1,0,3,6,5,4,7,10,9,8,11)
Translator Type 13 [AU6983,AU6986]
Bank Size1024
Add-Ins Size32
Add-Ins Offset8
GMT+8, 2026-7-12 19:01 , Processed in 0.100467 second(s), 13 queries .
