查看: 2948|回复: 0
【USB Flash】SM324QF BC A95347 0814 S8T [复制链接]
发表于 2011-11-9 05:58:03 |只看该作者 |倒序浏览
Controller marking :  SM324QF BC A95347 0814 S8T
Memory chip marking :  K9LAG08U0A
Memory chip ID :  0xECD555A5
Split by dump (Dump number 2)
Join by block for pairs (Block Size 2097152)
Translator Type 7 [SM324QF BC]
Variant 2 Author: GreyDKang [139]
Join by block for pairs (Block Size 2097152 )
Block Number Type 2 [SM32xx]
Use Add-insNo
Full blocksNo
GMT+8, 2026-7-12 18:12 , Processed in 0.096726 second(s), 13 queries .
