查看: 2522|回复: 0
【USB Flash】UT163-L6 _ AP00317 _ 0740 A18 [复制链接]
发表于 2011-11-9 07:16:12 |只看该作者 |倒序浏览
Controller marking :  UT163-L6 _ AP00317 _ 0740 A18
Memory chip ID :  0xECD55525
Variant 1 Author: WalRos [85]
1302
Even BlockYes
GMT+8, 2026-7-12 20:45 , Processed in 0.101120 second(s), 13 queries .
