查看: 2477|回复: 0
【USB Flash】PS2237-F UT0933 HLMP00EXB [复制链接]
发表于 2011-11-9 07:55:12 |只看该作者 |倒序浏览
Controller marking :  PS2237-F UT0933 HLMP00EXB
Number of parts :  4
Memory chip marking :  29F64G08CAMD2
Memory chip ID :  0x89D7943E
Capacity(Mb) :  16384
Variant 1 Author: bsj3386 [7]
Mask0x0FFF
GMT+8, 2026-7-12 23:00 , Processed in 0.098096 second(s), 13 queries .
