查看: 2363|回复: 0
【USB Flash】AU6983 [复制链接]
发表于 2011-11-9 09:52:16 |只看该作者 |倒序浏览
Controller marking :  AU6983
Memory chip marking :  HY27UA08T2MTR
Memory chip ID :  0xADD514B6
Variant 1 Author: d43 [99]
Change order (New order 1,0)
Translator Type 13 [AU6983,AU6986]
Bank Size1024
Add-Ins Size32
Add-Ins Offset8
Variant 2 Author: pad-dataservice [17]
Bank Size1024
Add-Ins Size8
Add-Ins Offset8
GMT+8, 2026-7-13 00:51 , Processed in 0.103014 second(s), 13 queries .
