查看: 2267|回复: 0
【USB Flash】UT163-L6 APD0167 0718 A1B [复制链接]
发表于 2011-11-9 09:13:06 |只看该作者 |倒序浏览
Controller marking :  UT163-L6 APD0167 0718 A1B
Memory chip ID :  0xADD314A5
Capacity(Mb) :  1024
Variant 1 Author: admin [46]
Even BlockYes
GMT+8, 2026-7-13 02:59 , Processed in 0.093191 second(s), 13 queries .
