查看: 2422|回复: 0
【USB Flash】UT163-T6 BAG022 0805 A10 [复制链接]
发表于 2011-11-9 07:54:54 |只看该作者 |倒序浏览
Controller marking :  UT163-T6 BAG022 0805 A10
Memory chip marking :  HY27UV08BG5M
Memory chip ID :  0xADD555A5
Variant 1 Author: l32 [63]
1302
Even BlockYes
GMT+8, 2026-7-12 23:43 , Processed in 0.095758 second(s), 13 queries .
