查看: 2256|回复: 0
【USB Flash】AU6984 A53-MHL-GR A94409-033 0809T [复制链接]
发表于 2011-11-9 09:12:50 |只看该作者 |倒序浏览
Controller marking :  AU6984 A53-MHL-GR A94409-033 0809T
Number of parts :  4
Memory chip ID :  0xECD755B6
Capacity(Mb) :  32768
Variant 1 Author: admin [46]
Parts of memory chips (8)
13570246
Change order (New order 1,3,5,7,0,2,4,6)
Translator Type 12 [AU6984]
Bank Size1024
Block Size8192
Add-Ins Size64
Add-Ins Offset8
GMT+8, 2026-7-13 03:06 , Processed in 0.099511 second(s), 13 queries .
