查看: 2347|回复: 0
【USB Flash】JMF602 0946 BICA0B [复制链接]
发表于 2011-11-9 09:12:45 |只看该作者 |倒序浏览
Controller marking :  JMF602 0946 BICA0B
Number of memory chips :  6
Memory chip marking :  MT29F32G08TAA
Memory chip ID :  0x2CD7D53E
Capacity(Mb) :  49152
Variant 1 Author: Sheremetov [67]
012345
Initial memory chips (6)
01234567891011
Parts of memory chips (12)
01234567891011
Copy in preparation results
012345
Join by block fo N sources (Block Size 16)
Split by block (Block Size 6144)
Join by block for pairs (Block Size 48)
Join by block for pairs (Block Size 96)
sequence of conversions is not correct! Please check the corectness of solution!
SSD: JMICRON JMF601/JMF602
Block Size24576
GMT+8, 2026-7-13 03:06 , Processed in 0.191258 second(s), 13 queries .
