查看: 2457|回复: 0
【USB Flash】UT163-L6 BPD0379 [复制链接]
发表于 2011-11-9 07:54:34 |只看该作者 |倒序浏览
Controller marking :  UT163-L6 BPD0379
Memory chip marking :  HY27UU(T)084G2M
Memory chip ID :  0xADDC8425
Capacity(Mb) :  1024
Variant 1 Author: Mekanik [14]
Change order (New order 1,0)
Even BlockYes
GMT+8, 2026-7-12 23:06 , Processed in 0.109716 second(s), 13 queries .
