查看: 3015|回复: 0
【USB Flash】SM268BF BB _ QSUU53.1 [复制链接]
发表于 2011-11-9 06:36:13 |只看该作者 |倒序浏览
Controller marking :  SM268BF BB _ QSUU53.1
Memory chip ID :  0xECD514B6
Variant 1 Author: WalRos [85]
Change order (New order 1,0)
Block Number Type 2 [SM32xx]
Use Add-insNo
Full blocksNo
GMT+8, 2026-8-26 23:04 , Processed in 0.125298 second(s), 13 queries .
