查看: 3139|回复: 0
【USB Flash】PS2231 0736 AJF3W 000ED [复制链接]
发表于 2011-11-9 06:35:56 |只看该作者 |倒序浏览
Controller marking :  PS2231 0736 AJF3W 000ED
Memory chip marking :  TH58NVG4D4CTG00
Memory chip ID :  0x98D585A5
Variant 1 Author: maestro [5]
1302
Split by dump (Dump number 4)
Mask0x0FFF
GMT+8, 2026-8-26 23:41 , Processed in 0.105023 second(s), 13 queries .
