查看: 2586|回复: 0
【USB Flash】UT165-L48 N43A5 0913 ADA [复制链接]
发表于 2011-11-9 07:53:58 |只看该作者 |倒序浏览
Controller marking :  UT165-L48 N43A5 0913 ADA
Number of memory chips :  4
Memory chip marking :  29F32G08AAMD2
Memory chip ID :  0x89D7943E
Capacity(Mb) :  32768
Variant 1 Author: rodzappa [6]
Initial memory chips (4)
Parts of memory chips (8)
Copy in preparation results
13025746
Change order (New order 1,3,0,2,5,7,4,6)
Block Number Type 9 [0x4001]
Even BlocksNo
Page size 8608
Sector size 568
0-512;8576-32;512-24;
536-512;8576-32;1048-24;
1072-512;8576-32;1584-24;
1608-512;8576-32;2120-24;
2144-512;8576-32;2656-24;
2680-512;8576-32;3192-24;
3216-512;8576-32;3728-24;
3752-512;8576-32;4264-24;
4288-512;8576-32;4800-24;
4824-512;8576-32;5336-24;
5360-512;8576-32;5872-24;
5896-512;8576-32;6408-24;
6432-512;8576-32;6944-24;
6968-512;8576-32;7480-24;
7504-512;8576-32;8016-24;
8040-512;8576-32;8552-24;
GMT+8, 2026-7-12 23:01 , Processed in 0.099820 second(s), 13 queries .
