查看: 2309|回复: 0
【USB Flash】UT161-T6G [复制链接]
发表于 2011-11-9 08:33:01 |只看该作者 |倒序浏览
Controller marking :  UT161-T6G
Memory chip ID :  0xADDC8095
Variant 1 Author: icanrc [6]
1302
Block Size512
Even BlockNo
GMT+8, 2026-7-13 00:33 , Processed in 0.099054 second(s), 13 queries .
