查看: 2348|回复: 0
【USB Flash】UT163-Q4 APDT013 0710 A1B [复制链接]
发表于 2011-11-9 09:51:04 |只看该作者 |倒序浏览
Controller marking :  UT163-Q4 APDT013 0710 A1B
Memory chip marking :  NAND04GW3B2B
Memory chip ID :  0x20DC8095
Capacity(Mb) :  1024
Variant 1 Author: vip [102]
Change order (New order 1,0)
Block Size512
Even BlockYes
GMT+8, 2026-7-12 21:01 , Processed in 0.117592 second(s), 13 queries .
