查看: 3213|回复: 0
【USB Flash】UT163-L6 APD0146 0717 A1B [复制链接]
发表于 2011-11-9 06:35:37 |只看该作者 |倒序浏览
Controller marking :  UT163-L6 APD0146 0717 A1B
Memory chip marking :  HY27UV08BG5M
Memory chip ID :  0xADD555A5
Variant 1 Author: l32 [63]
Parts of memory chips (2)
Even BlockYes
GMT+8, 2026-8-26 23:40 , Processed in 0.139351 second(s), 13 queries .
