查看: 2521|回复: 0
【USB Flash】PL-2528 LF08033A [复制链接]
发表于 2011-11-9 09:50:47 |只看该作者 |倒序浏览
Controller marking :  PL-2528 LF08033A
Memory chip marking :  HY27UV08BG5M
Memory chip ID :  0xADD555A5
Variant 1 Author: l32 [63]
Copy in preparation results
1302
Marker Pos520
Full Block? (default)
GMT+8, 2026-8-26 23:41 , Processed in 0.139666 second(s), 14 queries .
