查看: 2569|回复: 0
【USB Flash】UT163-LQ4 APDO319 0740-A1B [复制链接]
发表于 2011-11-9 07:21:41 |只看该作者 |倒序浏览
Controller marking :  UT163-LQ4 APDO319 0740-A1B
Memory chip marking :  JS29F08G08AAMB2
Memory chip ID :  0x89D394A5
Capacity(Mb) :  1024
Variant 1 Author: ССЦ [5]
Even BlockYes
GMT+8, 2026-7-12 21:37 , Processed in 0.120752 second(s), 13 queries .
