查看: 2398|回复: 0
【USB Flash】UT163-LQ4 BPDO412 0750 A1B [复制链接]
发表于 2011-11-9 09:18:53 |只看该作者 |倒序浏览
Controller marking :  UT163-LQ4 BPDO412 0750 A1B
Memory chip ID :  0xADD314A5
Variant 1 Author: ССЦ [5]
Parts of memory chips (2)
Even BlockYes
GMT+8, 2026-7-13 02:46 , Processed in 0.094405 second(s), 13 queries .
