查看: 2813|回复: 0
【USB Flash】UT176-L6 _ APD0398 _ 0748 A2C [复制链接]
发表于 2011-11-9 07:21:38 |只看该作者 |倒序浏览
Controller marking :  UT176-L6 _ APD0398 _ 0748 A2C
Memory chip ID :  0xECD55525
Variant 1 Author: WalRos [85]
1302
Even BlockYes
GMT+8, 2026-7-12 22:19 , Processed in 0.105911 second(s), 13 queries .
