查看: 2854|回复: 0
【USB Flash】AU6984 A53-MHL-GR A99113-1F [复制链接]
发表于 2011-11-9 06:42:29 |只看该作者 |倒序浏览
Controller marking :  AU6984 A53-MHL-GR A99113-1F
Memory chip ID :  0xECD514B6
Variant 1 Author: serviceman [4]
Change order (New order 1,0)
Translator Type 12 [AU6984]
Bank Size1024
Add-Ins Size32
Add-Ins Offset8
GMT+8, 2026-7-12 18:11 , Processed in 0.102247 second(s), 13 queries .
