查看: 2319|回复: 0
【USB Flash】AU6984 A53-MHL-GR A94409-033 0809T [复制链接]
发表于 2011-11-9 08:00:33 |只看该作者 |倒序浏览
Controller marking :  AU6984 A53-MHL-GR A94409-033 0809T
Number of parts :  4
Memory chip ID :  0xECD514B6
Capacity(Mb) :  16384
Variant 1 Author: epema [13]
Parts of memory chips (8)
0132
Change order (New order 0,1,3,2)
Change order (New order 1,0,2)
Translator Type 12 [AU6984]
Bank Size1024
Block Size8192
Add-Ins Size64
Add-Ins Offset8
GMT+8, 2026-7-12 23:54 , Processed in 0.095595 second(s), 13 queries .
