查看: 2421|回复: 0
【USB Flash】UT163-L6 APD0004 0702 A1B [复制链接]
发表于 2011-11-9 08:38:51 |只看该作者 |倒序浏览
Controller marking :  UT163-L6 APD0004 0702 A1B
Memory chip marking :  HY27UV088G5
Memory chip ID :  0xADD38525
Variant 1 Author: alexey [122]
1302
Even BlockNo
GMT+8, 2026-7-13 01:20 , Processed in 1.257075 second(s), 14 queries .
