查看: 2527|回复: 0
【USB Flash】UT163-L6 BPD0434 0751 A1B [复制链接]
发表于 2011-11-9 07:20:29 |只看该作者 |倒序浏览
Controller marking :  UT163-L6 BPD0434 0751 A1B
Number of parts :  4
Memory chip ID :  0xADD314A5
Variant 1 Author: alexey [122]
Parts of memory chips (8)
13570246
Change order (New order 1,3,5,7,0,2,4,6)
Even BlockNo
GMT+8, 2026-7-12 21:27 , Processed in 0.095880 second(s), 13 queries .
