军达成数据恢复
查看: 88616|回复: 48
PC3000 PC3000UDMA+DE 升级最新英文 版本-4.79 中英文说明   [复制链接]
发表于 2011-8-6 18:40:17 |显示全部楼层
ACE-PC3000UDMA+DE 升级最新英文 版本-4.79 中英文说明
Seagate (U5, Barracuda xx)
       Corrected ROM writing for Barracuda IV;
       Corrected processing of defect table, optimized sorting algorithm;
       Utility initialization block at launch is turned into separate;
       Added SafeMode initialization parameter - "Slow initialization". This thing is important for those HDD, at which standard initialization leads to flashing of register led like Christmas tree garland (incomplete SATA interface of HDD with its microprogram, caused by "fast" initialization of SafeMode);
       Added possibility to launch utility with switched off COM port and switch it on from utility;
       In Utility operations for Data Extractor for families:
Barracuda V, 7200.7/8/9/10, momentus neptune/mercury/venus(5400.3)/corsair(5400.4),
momentus M72(7200.1)/Galileo/Galileo Plus (7200.2)
the following App cord modifications are available:
       - pending fix 1/2;
       - Not Handled Software Path;
       - Sys Sect Write Err;
       - LBA -> PCHS (ATA);
       - 1 overlay load block ;
       - Alt List save block;
       - omission of loading of damaged Alt List (System Sectors reading err 74);
       - direct writing of System Sectors (mainly – work logs / SMART);
       - System Sector writing from buffer (mainly – configuration modification);
       - correction of head map for data recovery (pairing);
These modifications enable to start HDD both at hardware (damaged heads etc) and software damages (damaged G-List etc).
       修正写ROM为了希捷 Barracuda IV;
       缺陷表的处理修正, 优化运算法则排序;
       实用程序在启动的初始化块变成单独的;
       添加安全模式初始化参数 - "Slow initialization"(慢的初始化).这个事件是重要的为了那些硬盘, 在那标准的初始化引导到闪光的寄存器发光二极管像圣诞树光环 (不完整的SATA接口的硬盘的微程序,由“快”安全模式初始化造成的);
       添加可能的实用程序切断串行通讯端口(COM Port)和接通串行通讯端口(COM Port)从实用程序。
       在实用操作为了Data Extractor数据提取家族:
Barracuda V, Barracuda 7200.7/ Barracuda 7200.8/ Barracuda 7200.9/ Barracuda 7200.10, momentus neptune/mercury/venus(5400.3)/corsair(5400.4),
下列各项 APP 代码修正是可用的:
       - pending fix 1/2; (Pending 修理)
       - Not Handled Software Path; (处理软件通道)
       - Sys Sect Write Err;(体统扇区写错误)
       - LBA -> PCHS (ATA);(LBA扇区转到物理柱面磁头扇区)
       - 1 overlay load block ; (覆盖图1加载阻塞)
       - Alt List save block;(Alt 表保存阻塞)
       - 遗漏加载损坏的Alt List (System Sectors reading err 74); (系统扇区读错误47);
       - 直接写系统扇区(主要的–工作日志 / SMART);
       - 从缓冲区写系统扇区 (主要的 – 配置修正);
       - 为了数据恢复修正磁头地图 (配对);
这些更改允许去启动硬盘 两者在硬件 (损坏的磁头) 和损坏的软件 (损坏的 G-表).
Seagate F3
       Edit HDD ID dialog now has "Read retry" and "Disable IDLE activities" options. Capacity editing became more correct;
       Physical sector size detection method has been improved and has become more accurate (it is used at "Read with PC-3000 Active utility" mode and building head map in Data Extractor);
       New "Rescan physical sector size" button that rescans physical sector size has been added into utility status window;
       Now its possible to read drives more than 1 Tb with utility;
       Edit HDD ID options now has option for turning drive power supply off/on, after parameters were written. This option allows to avoid HDD hanging for a hard disk drive with "Pending bug" problem;
       SA Objects window has new "System files" tab added. This tab let you interact with system files over the terminal;
       Head map building for HDDs with 4k sectors is available in current version of utility;
       If damaged translator has "unnecessary" defects, you can use new function that allows you to set selected LBA to a certain position where reading is possible. That enables to recover reading at the beginning of area that contains necessary files.
Seagate F3
编辑硬盘ID对话框现在有“重试”和“禁用空闲活动”的选项。容量编辑变得更正确;
物理扇区大小发现方法有是改进的变得更精确 (它是使用的 在 "读用 PC-3000 Active utility" PC-3000活跃实用程序模式和建立磁头地图 in Data Extractor 在数据提取);
新的 "Rescan physical sector size" 重新扫描物理扇区大小,重新扫描的物理扇区大小的按钮已添加到实用状态窗口;
现在它是可能的读驱动器超过1TB在实用程序。
编辑硬盘身份操作现在有选项在参数写之后.为了翻转驱动器电源关闭打开, 这个选项允许去避免硬盘挂起为了一个硬盘驱动器关于Pending bug。
服务区目标窗口有新的 "System files" 系统文件表添加. 这个表让你用系统文件结合在USB 终端上;
在当前版本的实用程序里磁头地图建立为了硬盘用 4k 扇区是可用的。
如果损坏的编译器有不必要的缺陷,你能使用新的功能那允许你去设置选择LBA 扇区到某一位置,在那里读是可能的. 那允许去恢复读在开始的区域包含必要的文件
       - pending fix 1/2;
       缺陷表的处理修正, 优化运算法则排序;
       实用程序在启动的初始化块变成单独的;
下列各项 APP 代码修正是可用的:
Seagate F3
Seagate F3
如果损坏的编译器有不必要的缺陷,你能使用新的功能那允许你去设置选择LBA 扇区到某一位置,在那里读是可能的. 那允许去恢复读在开始的区域包含必要的文件。
Samsung
       For "Trinity" hard drives, new function that allows to write ROM ignoring "Platform ID check" has been developed. (Previous version returned "Invalid Platform ID" when you were trying to write ROM with different ID);
       For "Trinity" hard drives, we have added new "LED 1Axx unblock" instrument that lets hard drive enter ready state when LED 1A04/1A03 errors appeared within terminal.
       Now it is possible to read the data from hard drives with capacity more than 1 Tb with PC-3000 utility;
       ROM rewriting ability has been added for M7E Samsung drives family;
       At writing ROM on M7S2 and M7E hard drive families, automatic loader selection method than uses Platfiorm ID has been developed;
       New hex-editor plugins that fix modules checksum and view modules table has been added;
       "Identify data editor" and "View information about ROM dump" has been added for F3, F3_4D, F4, F4_3D, M7S2, M7 families;
       Additional verification method for reading ROM on "Trinity" hard drive families has been added;
       ROM writing ability for Trident, Storm2_G and Rubicon hard drive families has been added;
       Now it is possible to launch "Burn" manually for Trident and T166 hard drive families;
       "Command is not supported" error, that happened when "Downsize" flag was set within "Write BURN resources to hdd" dialog, has been fixed;
       New report creation for T-List and A-List defects allocation by zones is available;
       Techno-key autodetection method, that happens right after burn resources were loaded to hard drive, has been added;
       Automatic detection of technological ID size for cases where it is necessary, has been added;
       SA Structure test has been changed. Now it is possible to select certain system heads and turn off additional defects table and security system reports;
       New "Edit serial number" option for "Write BURN resources to hDD" test has been added; Option is available when loading Main-code
       For MT1 drives, new method for working on S-List2 and D-List2 defects (if they exist) has been added;
       Data Extractor interaction error that made impossible to build a head map after turning off power supply has been fixed;
       "Fix the gapes" option has been added to defects editor. That option allows to fill all free space between two nearest track or sector defects;
       "Utility extensions" menu now has "FIT editor" command. Now it is possible to edit the module itself and ROM image that has modules catalog;
       For M7E, F3, F3_4D, F4, F4_3D hard drive families, complete ROM image reading is now possible. All ROM image reading methods from previous utility version was preserved too.
       "Switch to external power supply unit" dialog, has been added to "Write burn resources to HDD" dialog;
       Translator regeneration error has been fixed for MANGO and M6S_2D hard drive families. The error was connected with defects from non-existent heads;
       New options for selecting the defect-lists output when building defect-lists report has been added
       Modules directory window layout has been changed ("Utility extension", "Modules Directory")
       Utility starts quicker with "Trinity" family. When using previous version of utility, you had to read the ID for several times to get correct zone allocation table data, but current version get correct data straight from GEO_TBL module;
       F4 and F4_3D families has been added;
       ROM interaction methods has been added for F3, F3_4D and M7E hard drive families;
       Reading data from drives with 4K sector size with Data Extractor "Reading from active PC-3000 Utility" method has been added for Samsung utility;
       M7E family hard drives manufactured in China are now supported (they have another technokey);
       Hard drive com-port terminal interaction algorithms have been improved.
Samsung USB
       Posibility to work via termianl with Trinity architecture drives (3,5" F1_3D and newer ones, 2,5" M7S2 and newer ones) has been added;
       We have eliminated the "hanging" problem of some tests when it was impossible to close utility if techno key sending error appeared;
       BURN running algorithms have been corrected taking into account the specifics of M7S2 and F3 families;
       All tests from PC-3000 kernel have been added.
三星
  • 对于"Trinity"(三位一体)的硬盘驱动器,新功能,可写忽视“ID”检查已经研制成功。(以前的版本返回“无效的平台ID”当你尝试写不同的ID ROM);
  • "Trinity"的硬盘驱动器,我们增加了新的“LED 1Axx解除封锁”的工具,在硬盘忙时,让硬盘驱动器进入就绪状态,当LED 1A04/1A03错误出现在终端。
  • 现在可以读从硬盘驱动器的数据容量超过1 TB用PC - 3000实用程序;
  • 已添加M7E三星硬盘系列ROM重写功能;
  • 在写ROM ,M7S2和M7E的硬盘驱动器的家族,自动装载选择方法比使用Platfiorm ID已开发;
  • 十六进制编辑器,修复模块的校验和查看模块表已添加新的插件;
  • “ID数据编辑器(硬盘型号编辑)”和“查看ROM转储信息”已添加在F3,F3_4D,F4,F4_3D,M7S2,M7的家庭;
  • 已添加额外的验证方法,阅读ROM上的"Trinity"的硬盘驱动器的家庭;
  • 已添加写ROM在Trident, Storm2_G 和 Rubicon 的硬盘家族;
  • 现在可以手动的发动 BURN(工厂自检) 在Trident and T166家族系列;
  • “命令是不支持”的错误,即发生“写入资源BURN到硬盘驱动器”对话框内设置"Downsize"的标记时,已得到修复;
  • 由区域分配表建立新的服告为了 T-List and A-List 缺陷表是可用的 ;
  • 在BURN 资源加载到硬盘驱动器之后 Techno-key  自动发现方法有添加;
  • 自动检测技术ID的大小,已添加;
  • SA结构测试已被更改。现在可以选择某些系统磁头,并关闭额外的缺陷表和安全系统报告;
  • 已添加新的“编辑序列号”选项“写入资源BURN 到HDD”测试选项时可用加载主代码
  • MT1的驱动器,工作在S-List2 and D-List2缺陷的新方法(如果它们存在)已添加;
  • 不可能建立在关闭电源后的磁头地图的数据提取互动错误已得到修复;
  • “修正的gapes”选项已被添加到缺陷的编辑器。该选项允许填补所有最近的两个轨道或扇区的缺陷之间的自由空间;
  • “实用程序的扩展”菜单“现在有"FIT editor"”命令。现在有模块目录,可以编辑模块本身和ROM映像;
  • 对于M7E F3_4D,F4,F3,F4_3D硬盘驱动器的家庭,完整的ROM映像读成为可能。所有ROM 映像读方法从以前的实用工具版本也保持。
  • “切换到外部电源供应器”对话框,已被添加到“写BURN资源,硬盘驱动器”对话框;
  • MANGO and M6S_2D硬盘驱动器的家庭的翻译器再生的错误已得到修复。错误是连接与来自不存在的磁头缺陷;
  • 已加入建立缺陷列表报告时,新的选择缺陷列表报告输出
  • Modules目录窗口布局已经改变(“Utility extension", "Modules Directory”)
  • 实用程序启动“"Trinity"”家庭更快。使用以前的版本的实用工具时,您曾多次读取的ID来获得正确的区域分配表中的数据,但目前的版本得到正确的数据直接从GEO_TBL模块;
  • F4和F4_3D家庭已添加;
  • ROM的交互方法已被添加为F3,F3_4D和M7E硬盘驱动器的家庭;
  • 用Data Extractor "读从 active PC-3000 Utility"  读数据从驱动器用4K扇区大小,已添加为了三星;
  • M7E家族驱动器在中国生产的硬盘驱动器现在支持(他们用另外的技术);
  • 硬盘驱动器的COM端口终端交互算法已得到改善。
三星的USB
  • 可能的通过终端工作(三位一体)的架构驱动器(3.5“F1_3D和更新的,2,5”M7S2和较新的)已添加​​;
  • 我们消除“悬挂”的一些测试问题时,这是不可能的接近实用,如果TECHNO发送错误出现​​;
  • BURN运行算法已得到纠正,考虑M7S2和F3家庭的具体情况;
所有的测试从PC - 3000的内核已被添加。
WD Marvell
       Added region reading/writing;
       Added support of Helios,Aztec PL families;
       Enhanced "Head map edit in RAM" mode for Dragon and Sadle 6G;
       Search module mode now can view modules with CHS access (if Search on HDD mode is chosen)
       Added specialized mode of region map editing;
       Added mode to eliminate "Slow Responding" (very slow execution of any command);
       Enhanced mode of map edit in RAM for 2.5” HDD families;
       "Search module" mode can now search for modules in SA on CHS;
       Added mechanism of SA SPT autodetection
(SA SPT request at inaccessible zone allocation table, "Utility state", "Search modules in SA");
       Added support of DF4 4KLT family;
       Added support of Vulcan RE family;
       Added support of Everest5 family;
       Added support of DF4PL RE family;
       Added support of Jamaica 4K family;
       Added support of Marn5 4K family;
       Added support of Dolphin family;
       Added support of Sadle BK, Esprit families;
       Added support of Sumt RE family;
       Added support of Manpl RE family.
WD Marvell USB
       COM port access has been implemented
WD的Marvell
  • 新增region(区域)读/写;
  • 新增支持的Helios,Aztec PL系列;
  • 增强的"Head map edit in RAM"(磁头地图编辑在RAM) 模式为了  Dragon and Sadle 6G”家族;
  • 搜索模块的方式,现在可以查看模块用CHS的访问(如果选择了HDD方式上的“搜索”)
  • 新增region(地区)的地图编辑的专业模式;
  • 增加的模式,以消除"Slow Responding" (慢响应)(非常缓慢的任何命令的执行);
  • 2.5“硬盘驱动器的家族增强模式地图编辑;
  • “搜索模块”的模式,现在可以搜索在SA(服务区)里CHS模块上;
  • 新增SA SPT的自动检测机制
    (SA SPT的请求在达不到的区域分配表,“实用状态”,“搜索模块在SA” );
  • DF4   4KLT家庭增加的支持;
  • Vulcan RE系列增加的支持;
  • 新增Everest5家庭的支持;
  • 新增支持DF4PL RE系列;
  • 增加Jamaica 4K家庭的支持;
  • 增加Marn5 4K的支持;
  • 增加Dolphin家庭的支持;
  • 新增支持Sadle BK,Esprit的家庭;
  • SUMT RE系列增加的支持;
  • 增加Manpl RE系列的支持。
WD Marvell公司的USB
  • COM端口的访问已实现
Toshiba
       Added support of 22GAS family;
       "Defects hiding" method has been improved;
       Added support of 16GAP, 55GSX, 59GSX families;
       CP sizes are corrected for 46GSX, 52GSX, 63GSX families;
       Added manual addition of LBA defects into P-List;
       Added saving of defects into P-List;
       Added grouping of defects into tracks;
       Added statistics of defects according to zones;
       Added SA track reading mode;
       Terminal speed has been increased for SATA HDDs with data access over terminal;
       P-List processing has been improved. Now P-List can have defects added after logical scan;
       Added control of integrity at data reading/writing through COM port.
东芝
  • 新增22GAS家族的支持;
  • “缺陷隐藏”的方法已得到改进;
  • 新增支持16GAP,55GSX,59GSX家族;
  • CP大小修正为了46GSX,52GSX,63GSX家族;
  • 手动添加LBA的缺陷到P-LIST;
  • 保存缺陷到P - LIST;
  • 添加缺陷分组到磁道;
  • 添加依照区域的缺陷统计;
  • 添加SA(服务区)磁道读模式;
  • 数据访问通过终端,终端的速度增强为了SATA 硬盘;
  • P - LIST处理得到了改善。现在P - LIST可以在逻辑扫描之后添加缺陷;
  • 在数据读写通过COM 端口添加完整的控制。
HITACHI-IBM
       Override ini has been corrected for HTS5450B9 family, information on SA Tops has been added into it;
       Utility error processing solution has been added. This enables you to read data within UDMA mode for cases where previous version could read the data only in PIO mode.
       For password removal its now possible to backup original security module. It helps to recover original password after getting access to data.
日立IBM
  • Override ini文件 已修正为了HTS5450B9家族, 在SA TOPS 上的信息已被添加;
  • 实用程序的错误处理解决方案已被添加。这允许你读数据在UDMA 模式为了案例,在那里先前的版本中是读数据仅在PIO模式。
  • 对于密码清除,它现在能备份原来的安全模块。它有助于获得数据后恢复原来的密码。
Data Extractor
       The support of file systems HFS+ and exFAT has been added;
       Quick disk analysis has been improved - HFS+, exFAT, XFS, EXT2(3,4) support has been added. Using information of GPT and Apple Partition Scheme while analysis performing has been added;
       NTFS, Mode of metadata map creation for files and folders has been added. It is useful when file is described by many MFT records (not by one);
       NTFS, "Problems with data stream" status for files, icon and message about it at saving have been added. This status is set when it is impossible to detect file location;
       An error of memory manager that caused unstable work in different modes has been fixed;
       Method of filtering for result of MFT table scanning has been improved;
       Possibility to show /to not show deleted files after MFT scanning has been added;
       Full path has been added into report of marked files and folders;
       Field of map capacity in Kb/Mb/Gb has been added into object map;
       Handling of enabled DRQ register at the moment of some command start has been added. Handling parameters are placed into parameter form;
       EXT4 support has been added;
       We have greatly modified and optimized the memory usage way and speed of the work of NTFS "native" file system and "MFT scan", "MFT+INDX scan" methods;
       New file types (mov, 3gp, mp4, etc) and file system structures (HFS+, exFAT) have been added to RAW recovery mode;
       Addressing in map mode has been fixed for LBA>2Tb (4294967296);
       For the HFS+, FAT, NTFS, XFS, exFAT, support of sector >512b has been added;
       The error which occurs while opening old tasks has been fixed;
       The error which occured at NTFS translator creation has been fixed;
       XFS and exFAT file systems are now supported;
       The support of sectors >512b has been added.
数据提取
  • 已添加HFS +文件系统和exFAT的支持;
  • 快速的磁盘分析工具得到了改进 - HFS+, exFAT, XFS, EXT2(3,4)  的支持已经增加。使用GPT和苹果分区配置的信息,分析执行已添加;
  • NTFS,元数据创建映射文件和文件夹模式已被添加。这是许多MFT记录所述的文件时非常有用;
  • NTFS 为了文件关于数据流的问题,图标和消息保存已添加,这个状态设置就在那个时侯不可能的去发现文件位置。
  • 造成不稳定的工作在不同模式下的内存管理错误已得到修复;
  • MFT表扫描的结果进行过滤的方法进行了改进;
  • 可以显示/不显示MFT的扫描后删除的文件已被添加;
  • 完整路径已被添加到标记文件和文件夹的报告;
  • 地图领域以KB / MB / GB的容量已被添加到目标的映射;
  • 启用DRQ登记处理一些命令开始的时刻已添加。处理参数放入参数的形式;
  • 已添加ext4支持;
  • 我们有很大的修改和优化的内存使用NTFS的“本地”文件系统“MFT扫描”,“MFT + INDX扫描”的方法的工作方式和速度;
  • 新的文件类型(MOV,3GP,MP4,等)和(HFS +的exFAT)文件系统结构已被添加到RAW恢复模式;
  • 在地图模式下寻址已修理为了LBA> 2TB(4294967296);
  • 对于HFS +格式,FAT,NTFS,XFS,exFAT,支持扇区 大于> 512字节已添加;
  • 打开旧任务时发生错误已得到修复;
  • NTFS翻译发生的错误已得到修复;
  • XFS和exFAT文件系统现在支持;
  • 支持的扇区大于 512字节已添加。
PC-3000 Kernel
       The error of HDD autodetection which caused wrong detection of HDD as Hitachi has been fixed;
       The asyncronous execution with interruption possibility has been added for all standard tools such as recalibration, sleep function, security, set MAX LBA;
       Com port work has been improved (reaction on activation/deactivation of PC-USB-Terminal "on the fly");
       Automatical request to change administrator's permissions for Windows 7 and Vista has been added;
       Addition to solution of the problem of "Folder of profile is already in use" has been done;
       The new switcher has been added to ATA, Hitachi native, Maxtor, Toshiba, Samsung and WD utilities for non-modal enter to utility.
PC - 3000内核
  • 造成日立的硬盘驱动器的错误检测的硬盘驱动器的自动检测的错误已修复;
  • 异步执行中断的可能性已被添加为所有标准工具,如校准,睡眠功能,安全性,设置最大的LBA;
  • COM端口的工作已得到改进(激活/去激活PC - USB终端);
  • 自动化的要求更改为Windows 7和Vista的管理员的权限已被添加;
  • 添加解决的这个问题 外部的文件夹是已经使用 已经完成;
新的转换器已被添加到ATA,Hitachi native, Maxtor, Toshiba, Samsung 和 WD实用程序非常见的进入实用程序
发表于 2011-8-6 18:59:45 |显示全部楼层
看了,OK!
    2015-3-21 11:03:01
  • 签到天数: 264 天
    发表于 2011-8-6 19:00:07 |显示全部楼层
    相当给力
    发表于 2011-8-6 19:20:16 |显示全部楼层
    了解一下
    发表于 2011-8-6 19:43:26 |显示全部楼层
    很不错, 要升级
    发表于 2011-8-6 20:53:27 |显示全部楼层
    内容增加的不错,但是翻译的有点看不懂呢?呵呵呵,还有其它的说明书呢?三星 东芝 WD的
    2018-10-18 13:59:27
  • 签到天数: 780 天
    [LV.10]以坛为家III
    发表于 2011-8-7 00:40:35 |显示全部楼层
    好东西要支持!!!!!!!
    顺德数据恢复中心
    专业数据恢复
    2014-3-10 08:36:58
    发表于 2011-8-7 08:12:38 |显示全部楼层
    看一下,已经升级完成了
    石家庄七星数据恢复中心     卡号  000177
    2021-3-10 11:45:24
  • 签到天数: 14 天
    发表于 2011-8-7 09:43:59 |显示全部楼层
    看了,功能更加强大了。
    2016-2-24 12:41:51
    发表于 2011-8-7 09:47:35 |显示全部楼层
    很好,收藏学习~!
    人生的意义在于修炼灵魂~提高自身修养~~!
    Archiver|手机版|军达成数据恢复PC3000 ( 京ICP备09023376号-1 )
    GMT+8, 2026-10-16 04:40 , Processed in 0.122244 second(s), 15 queries .
